stockxr Banned 123 Member For: 17y 5m 26d Gender: Male Posted 17/04/09 12:46 AM Share Posted 17/04/09 12:46 AM hey all, this week I had a few things put into the t, including...-fuel pump-valve springs-42lb boshies-and a cooler, and pippingthe power gain is awesome, I didn't hit peak due to a shagged stando cat, but I'm not fussed about that as its an easy fix, the thing that concerns me is..... after the tune, when the car is in drive and at a standstill for example at a red light the car shakes like a NASA air shuttle, if I chuck it in N the shaking ceases but if I put it into reverse it starts to shake again.while I'm driving it doesn't seem to be there. I have no idea what it is, the tuner reckons that it could be mu exhaust hitting something but its to vigorous for that.has any one had this problem after tuning there T, ant thing will hep thanks guys.regards adrian Link to comment https://www.fordxr6turbo.com/forum/topic/56812-shaking-vibration-argggg-help-pls/ Share on other sites More sharing options...
NVT Formerly EGOBFXR6 Donating Members 1,111 Member For: 17y 5m 13d Gender: Male Location: Perth, WA Posted 17/04/09 07:07 AM Share Posted 17/04/09 07:07 AM Is it idling very low at a standstill? That sometimes causes bad shudder...Any other funny problems? If it wasn't doing it before, then it has to be something to do with the tune then. It's probably not coils if it was fine befroe.You're best to take it back to the tuner mate, and get him to sort it out...Dan Link to comment https://www.fordxr6turbo.com/forum/topic/56812-shaking-vibration-argggg-help-pls/#findComment-862219 Share on other sites More sharing options...
stockxr Banned 123 Member For: 17y 5m 26d Gender: Male Posted 17/04/09 07:28 AM Author Share Posted 17/04/09 07:28 AM ye at a stand still in drive its sitting at abot 500-600 rpm, then wen its in N it sits about 1k-1100 and at that stage there is no vibration, do you recon its got any thing to do with the way the spark plugs have been gapped??? Link to comment https://www.fordxr6turbo.com/forum/topic/56812-shaking-vibration-argggg-help-pls/#findComment-862257 Share on other sites More sharing options...
turbo.vixen Hey guys, Tab is here... Oh i feel sick Lifetime Members 8,459 Member For: 17y 1m 25d Gender: Male Location: sunshine coast Posted 17/04/09 07:31 AM Share Posted 17/04/09 07:31 AM id check your engine mounts Link to comment https://www.fordxr6turbo.com/forum/topic/56812-shaking-vibration-argggg-help-pls/#findComment-862262 Share on other sites More sharing options...
stockxr Banned 123 Member For: 17y 5m 26d Gender: Male Posted 17/04/09 07:34 AM Author Share Posted 17/04/09 07:34 AM the thing is that there was nothing wrong befor the tune. could the tuner have busted them on the dyno, or somthing??? Link to comment https://www.fordxr6turbo.com/forum/topic/56812-shaking-vibration-argggg-help-pls/#findComment-862266 Share on other sites More sharing options...
turbo.vixen Hey guys, Tab is here... Oh i feel sick Lifetime Members 8,459 Member For: 17y 1m 25d Gender: Male Location: sunshine coast Posted 17/04/09 07:43 AM Share Posted 17/04/09 07:43 AM maybe with the new power it couldnt handle it, iv been around falcons all my life and those symptoms are a common sign of a busted mount Link to comment https://www.fordxr6turbo.com/forum/topic/56812-shaking-vibration-argggg-help-pls/#findComment-862273 Share on other sites More sharing options...
NVT Formerly EGOBFXR6 Donating Members 1,111 Member For: 17y 5m 13d Gender: Male Location: Perth, WA Posted 17/04/09 07:48 AM Share Posted 17/04/09 07:48 AM Yeah mate,It's idling too low then... My bet would be that you may need to have your plugs re-gapped. Vixen makes a good point as well.Good luck mate,Dan Link to comment https://www.fordxr6turbo.com/forum/topic/56812-shaking-vibration-argggg-help-pls/#findComment-862279 Share on other sites More sharing options...
benzau Member 38 Member For: 16y 8m 14d Posted 20/04/09 02:54 PM Share Posted 20/04/09 02:54 PM When my car did this, it was engine/gearbox mounts..Didn't snap on the dyno, but did as I left the tuner's carpark! Link to comment https://www.fordxr6turbo.com/forum/topic/56812-shaking-vibration-argggg-help-pls/#findComment-864243 Share on other sites More sharing options...
stockxr Banned 123 Member For: 17y 5m 26d Gender: Male Posted 21/04/09 02:01 AM Author Share Posted 21/04/09 02:01 AM ok cool thanks, how do I fix the problem if it is the engine/gearbox mounts??? where are they? Link to comment https://www.fordxr6turbo.com/forum/topic/56812-shaking-vibration-argggg-help-pls/#findComment-864316 Share on other sites More sharing options...
NVT Formerly EGOBFXR6 Donating Members 1,111 Member For: 17y 5m 13d Gender: Male Location: Perth, WA Posted 21/04/09 07:09 AM Share Posted 21/04/09 07:09 AM I don't think it's something you can fix yourself...I'd wait til Vixen comes back. He'll have the answer. I'm sure your mechanic/tuner could sort you out mate.Dan Link to comment https://www.fordxr6turbo.com/forum/topic/56812-shaking-vibration-argggg-help-pls/#findComment-864488 Share on other sites More sharing options...
