March 15, 200917 yr #1 well droped my ute off at CV on saturday and should be ready too be picked up on friday, im hoping it makes around the 370wkw mark, mods arerapid v3.5 kitxforce 4inch dump, 3.5inch cat, single 3.5inch rest of the waywalbro gss 341siemens deka injectors 60lbs12lb actuator, ported wastegate/bigger flapperalso has stronger bottom end so will be running bit more boostso how close do you think I will get to 370 and what will max out first??
March 15, 200917 yr #4 Author so the single 3.5inch is too small? I thought the xforce systems were good for 400rwkw?
March 15, 200917 yr #5 looks like your doing all the right mods, especially the actuator/flapper mod.your power output will depend on model/transmission.more details!!
March 16, 200917 yr #8 I'm with senna, Clutch will max out first (if you have not upgraded). I would also add a surge tank and pump. Don't forget to post up completed picks....
March 16, 200917 yr #9 Author yeah mate also doing clutch, gone for a tex twin plate/sprung centre, I will see how it goes for now and hopefuly dosnt surge, but next few mods will be plenum and surge tank/bosch 044
March 16, 200917 yr #10 No real reason why it wont make the power as there's plenty of cars with the same set-ups with that power.But, cars are cars so results will always vary... some of those exhausts have been a bit sketchy with power levels, some make big power, others have struggled.
