February 5, 200917 yr #1 Hi all,I am buying a xr6 turbo, 03-05 model adn want to knwo some good mods to do with a fairly constrictive budget.I am looking at spending around $6,000 on the engine/exhaust so any suggestions on where to look?I live in WA and have looked around the Nizpro and APS sites but wondering if there is anything else out there?Purely mods to make it go harder.Lorenz
February 6, 200917 yr #2 Mate do a search. There are countless topic on this.To put it short.You will need... Capa flash tuner, new high flow fuel injectors, high flow CAT, valve springs, fuel pump, exhaust and if the budget will stretch a new intercooler.These kinda mods should see around 300rwkw.Dont forget if you buy a manual get the 6 speed and budget for a clutch. If you get an auto budget for a gearbox re build (4 speed auto) If you get the six speed auto they are pretty strong. Seen a stock on with over 400rwkw and no dramas
February 6, 200917 yr #3 what he said although I would go injecters ,intercooler ,cat ,fuel system ,and valve springs will be neede somewhere along that lot whenever your workshop tells you there've had enough look through site sponsers and tech sections
