Ba Xr Install Help
Featured Replies
#1
Hi I just bought a BA XR6 UTE and I wish to install into it:
1 x 12" Subwoofer 300W (Have)
1 x 4-Ch Amp 600W (Have)
4 x 6x9 Speakers 160W (Have)
MABY 2 x 6.5" Kevlar Splites with 1" Tweeters 60wrms with 120W total Power (if amp can handel it)
also have lying around
2 x 6.5" Kevlar Splits with 1" Tweeters 60wrms with 120W total Power
2 x 6x9" Kevlar with 1" tweeters 80 wrms
1 x 12" subwoofer 180W
*What is WRMS*
I need the dimensions of a subwoofer box to fit behind the drivers seat and maybe some pictures of some previously installed Sub Amp Configurations so I could get some ideas.
What size and how many speakers are already installed in these utes standard???
Any other idea suggestions wont go astray.
cheers
#2
****Summon Smickey or Quadie*****
:bangcomputer:
#3
wrms is the nominal running power, your speakers are 120w peak and 60 rms so they are 60w speakers, the max power figure is just a
selling point. same as your sub its 300w max but 150rms. my subs are 400rms so 800 watt max.
as for speakers in the utes standard there one in each door one behind each seat and I got tweeters in the pillars in corner of dash
Edited by sickd
#4
*What is WRMS*
cheers
I had a BA ute showcar a few years ago and I 2 x 12" 1000wrms behind the seat and 6"splits in the doors, and 2 amps. so you will have no problem with your install but you will lose the back speakers but trust me it will sound crazy if boxed right.
you should maybe try and fit both pairs of splits in to get a bit more of a blance??
#5
  • Author
I have removed the standard rear speakers and put in the 160W 6x9's yesterday
and I will put the 6.5" Splits in the front when I have time,
I am going to put the amp under the passenger seat and a 12" sub behind the passenger seat.
Will the amp be able to run:
the 6.5" splits in front
the 6x9's in rear
and the sub
My sub is 300 WRMS so it would be 600W max.
if this all goes to plan my ute will just pump the sound out.
#6
the 6x9's in rear
and the sub
don't think you'll be able to use the amp for everything as it's only a 4 channel, you would need another amp of a 5 channel to do everything
#7
  • Author
could I run the front speakers just of the standard system and then the sub and the rear speakers off the amp?
#8
you could but then the fronts would have trouble keeping up, if anything run the backs of the standard system and use the amp for your fronts and sub. the 6x9 to me are useless as you will have good midrange from your fronts and bass from you sub.
Recently Browsing 0
