pulonium Member 11 Member For: 16y 8m 15d Posted 04/10/08 10:26 PM Share Posted 04/10/08 10:26 PM (edited) I think I may have overdone the mods a little (custom tune, 10 psi, injectors, air, exhaust), 1st gear shoots by so fast now that occasionally the ZF (in auto mode) can't change to 2nd gear in time and the stupid rev limiter kicks in and I get thrown forward in my seat.I can change it in manual mode ok but it's really dicey, spending too much time focusing on the rpm.Has anyone else had this problem? Can anyone think of a way to work around it?I thought of a couple of options in theory, not sure what's involved, who I could get to do them or if they are even possible....1) Removing the rev limiter?2) Port the wastegate or add a new bigger one so the gasses can escape and prevent overboosting? 3) Can the ZF be programmed to change gears any quicker? )Was also wondering if changing the transmission oil etc might help speed the change a little, it does seem a tad slow than I'd expect)4) Making the 1st gear ratio a little taller from the 4.17 to a 4.10 or 4.0? (Personally I think the 1st gear ratio in the ZF is a little too short at 4.17)5) Bigger wheels on the car, bigger wheels give a taller gear ratio from memory?Thanks! Edited 04/10/08 10:28 PM by pulonium Link to comment https://www.fordxr6turbo.com/forum/topic/50388-help-after-mods-my-zf-if-hitting-the-rev-limiter-in-1st-gear-and/ Share on other sites More sharing options...
ravenhard Donating Members 1,517 Member For: 17y 2m 26d Gender: Male Location: Blacktown! Posted 04/10/08 10:46 PM Share Posted 04/10/08 10:46 PM I'd choose option 4. Go back to who ever did you custom tune tell them the problem and get them to fix it Link to comment https://www.fordxr6turbo.com/forum/topic/50388-help-after-mods-my-zf-if-hitting-the-rev-limiter-in-1st-gear-and/#findComment-744913 Share on other sites More sharing options...
trevs Member 781 Member For: 18y 1m 9d Gender: Male Location: balmain Posted 04/10/08 11:33 PM Share Posted 04/10/08 11:33 PM (edited) take it back to the tuner and get them to fix it Edited 04/10/08 11:33 PM by trevs Link to comment https://www.fordxr6turbo.com/forum/topic/50388-help-after-mods-my-zf-if-hitting-the-rev-limiter-in-1st-gear-and/#findComment-744926 Share on other sites More sharing options...
ravenhard Donating Members 1,517 Member For: 17y 2m 26d Gender: Male Location: Blacktown! Posted 05/10/08 01:02 AM Share Posted 05/10/08 01:02 AM did I say option 4? man it must of been too early for me. I meant option 3 the shift can be edited. Link to comment https://www.fordxr6turbo.com/forum/topic/50388-help-after-mods-my-zf-if-hitting-the-rev-limiter-in-1st-gear-and/#findComment-744959 Share on other sites More sharing options...
Cashie Donating Members 663 Member For: 22y 4m 3d Gender: Male Location: Perth Posted 05/10/08 03:41 AM Share Posted 05/10/08 03:41 AM Let me know how you go with this, I have the same issue... Link to comment https://www.fordxr6turbo.com/forum/topic/50388-help-after-mods-my-zf-if-hitting-the-rev-limiter-in-1st-gear-and/#findComment-744994 Share on other sites More sharing options...
pulonium Member 11 Member For: 16y 8m 15d Posted 05/10/08 06:06 AM Author Share Posted 05/10/08 06:06 AM well thanks for the advice guys, it sounds as though the conscientious is I take it back to the tuners and see if they can fix it (hopefully by tweaking the ZF's gear changes)I took it for a drive today with the cool weather it's hitting the rev limiter pretty much all the time :(will let you know how I go. Link to comment https://www.fordxr6turbo.com/forum/topic/50388-help-after-mods-my-zf-if-hitting-the-rev-limiter-in-1st-gear-and/#findComment-745039 Share on other sites More sharing options...
EZ2CME Formerly XR6NA Member 3,512 Member For: 19y 5m 29d Gender: Male Location: Brisbane Posted 05/10/08 06:32 AM Share Posted 05/10/08 06:32 AM Is it hitting the rev limiter because of wheel spin and it can't change up in time or is it hitting the rev limiter without wheel spin? Link to comment https://www.fordxr6turbo.com/forum/topic/50388-help-after-mods-my-zf-if-hitting-the-rev-limiter-in-1st-gear-and/#findComment-745045 Share on other sites More sharing options...
pulonium Member 11 Member For: 16y 8m 15d Posted 05/10/08 10:01 PM Author Share Posted 05/10/08 10:01 PM it's hitting the rev limiter without wheelspin, esp on or off traction isn't an issue.....I have a couple more ideas now:1. Get the tuner to increase the pressure in the auto lines so the gears change quicker2. Check the actuator is not over tightened/stickingI'm still reading a little about porting the wastegate in helping the overboost, it sounds feasible. Link to comment https://www.fordxr6turbo.com/forum/topic/50388-help-after-mods-my-zf-if-hitting-the-rev-limiter-in-1st-gear-and/#findComment-745308 Share on other sites More sharing options...
pulonium Member 11 Member For: 16y 8m 15d Posted 08/10/08 06:36 AM Author Share Posted 08/10/08 06:36 AM did I say option 4? man it must of been too early for me. I meant option 3 the shift can be edited.Update -All fixed, due to one or all of the following (I decided to do them all at once rather than trial and error):- Increased the pressure in the transmission lines by 10%- Changed the 1st gear shift point in ECU- Replaced auto transmission filter and oil with a premium synthetic oilit's changing oh so sweetly now even at 10psi! Link to comment https://www.fordxr6turbo.com/forum/topic/50388-help-after-mods-my-zf-if-hitting-the-rev-limiter-in-1st-gear-and/#findComment-746472 Share on other sites More sharing options...
PSYCHO XRT THE PSYCHO XRT Donating Members 1,275 Member For: 19y 5m 22d Gender: Not Telling Location: At the lights! Posted 08/10/08 06:50 AM Share Posted 08/10/08 06:50 AM Good to hear mate. Now go an enjoy it. :] Link to comment https://www.fordxr6turbo.com/forum/topic/50388-help-after-mods-my-zf-if-hitting-the-rev-limiter-in-1st-gear-and/#findComment-746478 Share on other sites More sharing options...
