September 9, 200818 yr #1 I bought a new oxygen sensor ($60 off ebay) and I was looking at changing it myself but its seems like a real tight spot (BA xr6t) and I can't get any sort of spanner on there. A guy from the ford service dept said you have to take all the heat shields off to access it... Is this true or can I get it with a small shifter or something else.cheers Edited September 9, 200818 yr by rule1110
September 9, 200818 yr #2 you'll only have to take the rear heat shield off, this takes about 1 minute. One of those ratchet ring spanners comes in handy here!
September 9, 200818 yr #3 Author Thanks mate, I haven't had a chance to look at it yet but they guy from ford made out like it was an hour long process. I'll check it out tommorrow.
September 9, 200818 yr #4 nah, if you have the standard crossover on there, take the two pipes off that go over the manifold side, then undo the threee bolts you need to take off the heatshield and this should give you a bit better access to the o2 sensor
