Matthew Green Member 10 Member For: 18y 11m Gender: Male Location: NSW Posted 06/08/08 09:42 AM Posted 06/08/08 09:42 AM Hi,I have a stock 03 XR6 Turbo.About once or twice a week when I start the car, it idles fine... then when putting it into drive, reverse or any other gear... The engine will shudder/miss very badly. I have to turn off the car and start it again, its then fine.Ive taken it to Ford and they said there was no error codes in the computer, they reflashed it for good measure anyaway. Problem is there Has anyone else had this issue, if so what did you do to fix it?Thanks.
Xrfranjo Member 350 Member For: 19y 1m 5d Gender: Male Location: Bonnyrigg Heights, NSW Posted 06/08/08 11:54 AM Posted 06/08/08 11:54 AM do a throttle body clean..... that could help you with the problem... start with the easy things and work your way back
Trough Lolly Member 4,349 Member For: 22y 19d Gender: Male Location: Mildura Posted 07/08/08 06:12 AM Posted 07/08/08 06:12 AM visit ford for a reflash maybe if your running the stock tune.
Matthew Green Member 10 Member For: 18y 11m Gender: Male Location: NSW Posted 08/08/08 10:54 AM Author Posted 08/08/08 10:54 AM Hi,They did a reflash no difference :(
