  • KILL,KILL,KILL,DIE,DIE,DIE,
  • Member For: 19y 10d
Hi people,
Is there a way to tighten the hand brake to bring down the amount of time it clicks before locking, I got defectd (suprise suprise) a few weeks ago and one of there bullsh*t things was my hand brake had 9 clicks insted of 7. So is there a way I can tighten it myself, or even a way just to make it only have 7 clicks.
Thanks
Michael.
  • Replies 53
  • Member For: 19y 10m 21d
get under the car and just behind the gearbox you will see where the cable comes out of the tunnel. there is an adjuster just before the cable separator. tighten her up and your on your way!
haha I tightened it too much first time I mucked around with it. its just trial and error sorry.
Edited by XR06T
  • Forged Member
  • Member For: 18y 3m 7d
You have to be careful when tightening from this end cos it can stretch the cable, the proper adjustment for the hand brake is through the rear hubs and is a pain in the arse! see how you go, but don't tighten it too much
  • Mmmmm......BOOST
  • Member For: 18y 16d
I did that all I got was the cyclic swish off the discs apperently if that happens I have to remove back wheels and ajust at the back of the discs havent done it yet though just slackened the cable back off again
hhhhhhhhhhmmmmmmm
maybe ill just jam som thing in the hand brake handle so it cant go all the way down then it wll save me some clicks.
It only need to pass the roady as the nah brake works just fine.
Edited by YPURV4
  • Forged Member
the handbrake design on the falcon is absolutely useless, it is basically a drum brake with a lock mechanism. Every ford mechanic hates adjusting a falcon handbrake, becasue they have to do it again in 2 months!
  • Member For: 19y 10m 13d
ideally you need to slack the cable, then tighten it through the drums until its locked and back it off1 to 1.5 turns and then adjust the cable to 5-7clicks.
if I was you I would get under the car and tighten the cable about 5 full turns and that will bring it within specs
