How To Check Actuator And Wastegate Operation
Featured Replies
#2
Get a air compressor with a air blower fitting and connect it to the hose on the actuator and ever so slightly give it a little air pressure and listen to see if flap opens.
I have had the flap in the turbo housing stick open before.
And at the moment I think I have a spilt in actuator membrane.
#3
Just furthering on beauies comments. It would be a lot safer to have the airline attached to a regulator so you don't blow the actuator diaphram to pieces. Then you can also test the accuracy of your actuator spring...
Cheers Trent
Recently Browsing 0
