Doggy Xr6t
Featured Replies
#1
Hey, Ive got an 02 xr6 turbo.
put it on the dyno only have 204 hp (152kw) found it had a crook fuel pressure regulator.
Replaced that, Ran it again, got 218 hp (162kw) still down on grunt.
The guy I bought it off drove it and said it was down on grunt
Where have all my horses gone.
Any suggestions guys?
cheers
Weeman
  • Replies 24
  • Views 2.1k
#2
You are going to need to have it checked out. It should be up near 200 at the wheels.
#3
Intake system airleaks, Turbo mount/exhaust manifold leaks, dirty airfilter, dirty fuel filter, dirty throttle body.
start with the itake hose and check for leaks. especially the rubber joiner on the throttle body.. :bowdown:
#4
  • Author
Yeah check for all that, ive tightend the exhaust manifold, new air filter, new fuel filter, taken out the injectors and cleaned them, cleaned the throttle body, replaced spring clamps in the intake hoses, Put the WDS and checked for anything outa place, its making all its boost according to the WDS
Im not scared to get into it, im mechanic by trade so I'm looking to things to try and fix it rather than give it someone to fix.
But thanks for the suggestions so far.
#5
Colapsed cat?
#6
:bowdown: sounds pretty much spot on...
#7
Failing that, get your local friendly dealership to take a look for you :bowdown:
#8
  • Author
Yeah, Im gonna have a look at the cat, took it to the dealership but they said there wasnt anything obvious. Even though they admitted it was down on power.
keep them coming guys!
Thanks !
Weeman
#9
mine was like that from new turns out the boost solenoid wasnt conected was barely makin any boost, have u had a boost guage on it
#10
hi weeman I see u found the site and still no luck with the T. :bum:
I was going to go see you and tell u to check the cat out, but u already on to it I see.
theres a lot of knowledge and good people on here to help u out and find wots wrong. :bum:
ps. just dont tell eny one were u work :spoton:
mick
Recently Browsing 0
