Zf Heat Issues
Featured Replies
#1
I have been at power cruise today chewing up a few cars but the tranny goes into limp mode from heat. Has anyone done a trans cooler for the 6 speed. I had a look on the hoist and there is 2 plastic lines and a heat sink attached to the block any sugestions?
#3
  • Author
343 rwkw
#4
They run a factory cooler, I think its water to oil, maybe look at getting a bigger one, or a air to oil?
#5
  • Author
yeah its like a little box its nolted to the block though. The lines going to it are plastic its weird. I was hopping someone else has done a swap already. Its fine for drag racing but didnt like 3 hot laps at eastern creek
#6
Iv'e been told that if you add a trans cooler you'll change the line pressure and the box goes into limp home mode.
#7
maybe fitting a larger one will reverse the problem and sort it out lol
surely theres gotta be sum1 whos tinkered with these boxes by now.. even a transcooler could make these so much better becuase I cant see them lasting behind some of these near 400kw phoons around now!
#8
The software is the problem, it can dectect a pressure drop and shuts itself down.
#9
The 40th anniversary GT has an upgraded auto trans cooler, it will probably also come with the R spec handling package for track work. This is one option to look at when it becomes available.
#10
Why would pressure drop?
If the unit is topped up with trans fluid to fill the extra volume and unless there are major reatrictions I don't see why pressure would drop even if it's going through a longer distance.
Rob.
Recently Browsing 0
