Auto Tranny Display Intermittent
Featured Replies
#1
Intermittently on about 5 occasions in the last month I have had the situation where I get into the car turn on the ignition and there is no P for Park showing on the dash display and then start normally and go to drive off in D and the D falshes and the it feels as though the auto is in the limp mode with torque converter locked up. Turn everyting off and re-start and all is well again.
This appears to happen generally from a cold start and never occurs whilst actually driving. WHen it does happen the spedo is fine so it's not a wheel sensor.
Any useful suggestion from those with similar experience or tranny experts.
It's a BA with the 4 Speed BTR box.
Dingah
#2
Flashing 'D' is a transmission error.
If it is intermittent, then I would check my connections, particularly the ones on the side of the transmission, as this could be a bad connection.
#3
  • Author
Yup, checked them and all appear ok.
Transmission drives fine so I doubt there is an actual fault more like a ddgy sensor somewhere?
Dingah
#4
There are not a lot of sensors in the 4 speed, I think only temp., so more likely faulty wiring.
Ford can connect the analyser and tell you what the error code is.
#5
  • Author
Now have downloaded codes which indicate S5 solenoid (adjustable line pressure) going to open circuit.
Connections and solenoid will be checked out and if necessary replaced next week (approx $70 for a replacment).
Dingah
#6
Sounds like you have a fried solenoid :spoton:
Good luck with the repair :fool:
#7
  • Author
Thanks Ninka - the valve body was modded by Tony Dominello at Dural a couple of years ago when tuning first began, so I am hoping that the solenoids remained standard in order to make sourcing a replacement easier.
Dingah
#8
  • Author
SO far so good. Glen a ESP pulled the pan down and thoroughly checked and re-assembled and crimped all loom connections and checked through the resistance of the loom and S5 slenoid and currently all appears good again.
Bloody hope so as it's a delibating fault!
Dingah
#9
That's good news mate, hope it's all sorted now
#10
Dingah
Good luck with that.
Hopefully by reporting an open circuit, it may just have been a poor connection on the solenoid connectors :blink:
Recently Browsing 0
