26/09/06 10:19 PM26/09/06 10:19 PM #1 Is there any truth in the rumour that the BF uses stronger Valve Springs & Con Rods than the BA ?
27/09/06 07:57 AM27/09/06 07:57 AM #2 Yes it is. I think this question came up a few months ago and it was confirmed that it does use stronger engine componets, such as those used by the Phoon's.I think the T engines in the BF's are now like the ZF gear box. . . Bulletproof! Edited 27/09/06 07:58 AM27/09/06 07:58 AM by Iconic Bionic
28/09/06 01:55 PM28/09/06 01:55 PM #3 yes it is true if it is an 06 build not 05 build I believe someone please correct me if I am incorrect.Rep
28/09/06 04:31 PM28/09/06 04:31 PM #4 that's what I heard, all bf xr6 turbo engine exactly like the F6 engine except no oil cooler. Anyone else who can confirm this from FORD?
28/09/06 08:47 PM28/09/06 08:47 PM #5 Author that's what I heard, all bf xr6 turbo engine exactly like the F6 engine except no oil cooler. Anyone else who can confirm this from FORD?←As far as I know the BF has a oil cooler.
29/09/06 09:46 AM29/09/06 09:46 AM #6 My 06 BF does not have a oil cooler, not sure about the Con Rods being the same as the F6 but if they are . KPM just ripped the springs off my head so mabey they can confirm the springs
29/09/06 10:01 AM29/09/06 10:01 AM #8 I'm told that the XR6T uses the same rods as the F6 and LPG Falcon. From what I understand these conrods are all exactly measured and examined the perfect rods go to the F6's the less than perfect rods go to the others.
29/09/06 10:05 AM29/09/06 10:05 AM #9 I'm told that the XR6T uses the same rods as the F6 and LPG Falcon. From what I understand these conrods are all exactly measured and examined the perfect rods go to the F6's the less than perfect rods go to the others.←Either way they are bound to be better than the bannanas found in ealier model T's
