January 9, 200620 yr #11 Author what if I was to just get the CAI, new thermostat,new hose clamps,and edit fitted and tuned.what would be holding me out from more power then? Injectors and fuel pump I guess!what sought of power could I get with standard pump and injectors? 260 - 280 rwkw?
January 9, 200620 yr #12 these injectors are the drilled out nizpro ones! are they any good?I do not want to be a pain in the neck and tell the tuner that I do not want the work done now, but I also need my car to be reliable!I have Nizpro drilled injectors and they are fine. They sound like they will fit in well with your proposed mods.
January 9, 200620 yr #13 I have Nizpro drilled injectors and they are fine. They sound like they will fit in well with your proposed mods.they may be, but how do they compare in price with Eugene's ????Also what pattern of spray are they???Personally I'd prefer them to be the correct angle/pattern/orifice from factory!Russ
January 9, 200620 yr #15 Author well I am the same if I could get the whole lot for $1500 why pay extra to get the stock stuff touched up, drilled out etc! this is not adding up to me there has to be some reasoning behind it all!# reading about eugenes injectors, the look the goods!
January 9, 200620 yr #16 how much are eugenes injectors!what should I be paying for some injectorsnew fuel pumpCAIand a CAPA that I am supplying to be fitted and tuned?$450 with pig tail lead
January 9, 200620 yr #17 I have Nizpro drilled injectors and they are fine. They sound like they will fit in well with your proposed mods.they may be, but how do they compare in price with Eugene's ????Also what pattern of spray are they???Personally I'd prefer them to be the correct angle/pattern/orifice from factory!RussNot sure exactly how they compare, all I know is they work great.Dont Eugenes need adaptors too?
January 9, 200620 yr #18 Dont Eugenes need adaptors too?You either have to change connectors in the loom or get adapters to suit. He supplies the connectors with the injectors & I did supply a few people the adapters who wanted a simple plug & go answer!Russ
January 9, 200620 yr #19 ell I am the same if I could get the whole lot for $1500 why pay extra to get the stock stuff touched up, drilled out etc!this is not adding up to me there has to be some reasoning behind it all!What have they quoted you???You can Walbro pumps on ebay for $125-$200Russ
January 9, 200620 yr #20 Author I am not trying to stir any sh*t here but for $1650I can get my edit fitted and tunedfuel pump modifiedCAIinjectors drilled outnew hose clampsand a colder thermostat so the $1500 is fairly closeFor $1950I can get a brand new pump, not sure if it is the Walbro type! Eugenes injectors look pretty good so far!
