November 14, 200520 yr #1 Was in jaycar today and happened to notice this little box!http://www.jaycar.com.au/productView.asp?I...eMax=&SUBCATID=12 volt does ntsc what more could you want?It doesnt output a rgb signal (if you dont have a blau box) well have a look at this!http://www.jaycar.com.au/productView.asp?I...eMax=&SUBCATID=have I missed something or is it just this easy!
November 14, 200520 yr #4 Author I know about the rest but thought I would let people know about this easy sloution!
November 14, 200520 yr #5 12 volt does ntsc what more could you want?well a tuner that actually works for a start ask the people in the store to show you one WORKING! when they say good signal area they mean parked under a repeater station
November 14, 200520 yr #6 Author was working in the store surrounded by a whole heap of other electrical equipment and appeared to be working well.For some reason wouldnt let me take it out to my car and drive around!?!?! (something about stealing it)
November 14, 200520 yr #7 I'm glad it worked for someone, 100% fail rate would a bit much but the 4 that I tried were all big pieces of what state you in travis?? I'd love to see one of these working (without a house antenna)
November 14, 200520 yr #8 Author with this box?I just saw it in the store, am interested but if you had that kind of experience I will steer clear.
November 14, 200520 yr #9 It doesnt output a rgb signal (if you dont have a blau box) well have a look at this!http://www.jaycar.com.au/productView.asp?I...eMax=&SUBCATID=have I missed something or is it just this easy!I was under the impression (when reading through the long thread on digital tv) that the output of the digital set top box being used was an interlaced signal (via SCART), I.e. the Ford ICC takes a RGB+Sync NTSC interlaced signal. If this is the case, then the converter that you mention above will not work.Can anyone confirm this? Or at least put me in my place
November 14, 200520 yr #10 It doesnt output a rgb signal (if you dont have a blau box) well have a look at this!http://www.jaycar.com.au/productView.asp?I...eMax=&SUBCATID=have I missed something or is it just this easy!<{POST_SNAPBACK}>I was under the impression (when reading through the long thread on digital tv) that the output of the digital set top box being used was an interlaced signal (via SCART), I.e. the Ford ICC takes a RGB+Sync NTSC interlaced signal. If this is the case, then the converter that you mention above will not work.Can anyone confirm this? Or at least put me in my place <{POST_SNAPBACK}>I think you're right ROBiiE
