  • Member For: 22y 5m 11d
Posted
For the people who have oil pressure guages fitted, just wondering what should the oil pressure be when cold and after some hard driving? :spoton:
Shane
  • Legacy Donating Member
  • Member For: 20y 11m 24d
Posted
I would like to know the same.
my gauge nearly hits 4.5 when cold and around 1.5 - 2 when hot/hard driving.
but have no idea what it means :spoton:
  • F6+300+
  • Member For: 21y 10m 20d
Posted
On the factory oil mine run @ 22~30PSI/150~200kpa hot at idle
10w60 Formula R hot at idle was @ 58psi/400kpa
0w40 Formula R hot at Idle is @ 46psi/300kpa
Probably drop lower on factory thermostat but at the moment I run a 170deg so the oil is not as hot as STD.
At present I run the 0w40 Formula R and it seems to run from @ 300kpa @ idle to @ 450~500kpa with open throttle.
Posted
<{POST_SNAPBACK}>
Mine used to be around 52 psi when cold and around 24 psi @ idol after some spirited driving, it actually dropped 2-3 psi when both hot and cold after changing to mobil1 5w50. Im thinking that when hot the pressure seems a bit low for a car with 35k on it. :laughing:
Shane
  • Yes I am too tall for my hair
  • Member For: 21y 11m 27d
Posted
Where did you guys plumb the oil sender in
Thanks
  • F6+300+
Posted
Thanks
<{POST_SNAPBACK}>
The F6 has an Oil pressure guage
Posted
Thanks
<{POST_SNAPBACK}>
You have to get a T piece to screw into the block where the factory oil pressure switch is
Shane
Posted
Thanks
<{POST_SNAPBACK}>
Shane
<{POST_SNAPBACK}>
did you put the sender in there or run a remote oil line and do you get some thing made up or is there a part you can buy and what threads please
thank guys
Posted
Thanks
<{POST_SNAPBACK}>
Shane
<{POST_SNAPBACK}>
thank guys
<{POST_SNAPBACK}>
The T piece screws into the block, the factory oil pressure switch goes on the end of the t piece and the sender you get with your guages goes into the T piece. What brand guages have you got? Im sure ive got a part number for a t piece if your using autometer stuff somewhere
Shane
