shockwavexr6t Member 50 Member For: 21y 5m 28d Posted 02/11/05 10:49 PM Posted 02/11/05 10:49 PM Hi Everyone,Well I fitted the ase ic the other week and the dump 3.5in waste gate 1.inch and 3.5 met cat as seen pictures below the dump pipe and cat made boost peak to 18psi not good, well it booked it in to nizpro for a retune not the best day to dyno car 32degrees very hot. Well peak power was 305rwkws with sligth pinping end result 295rwkws just to be safe boosted at 14psi. Maybe if it was cooler the results would have been interesting. Well Dave at nizpro said the ic dealt heat soak OK and better than standard ic, so if ase can build ic that can handle 32degree heat I'm pretty happy with that.Mod's to car 2nd cai, edit, 968, valve springs,ic,dump pipe and cat.The only weakness is the standard ic pumping. with shorting plumping results would be better more responsive. The standard clutch is fine at the moment.sorry the photo quality was from my camera phonecheersGeorge
blueboost Member 1,204 Member For: 22y 4m 4d Gender: Male Location: Mackay NorthQueensland Posted 02/11/05 11:02 PM Posted 02/11/05 11:02 PM Well done sounds good, did you get a printout of your psi and afr?
RAPHOON Legacy Donating Member 1,776 Member For: 23y 3m 4d Posted 02/11/05 11:56 PM Posted 02/11/05 11:56 PM That sure looks like a nice piece of kit.How much and from where??
turb06 Dark Knight Mafia Member No. - 666 Member 3,667 Member For: 23y 7m 6d Location: Toowoomba Posted 03/11/05 02:21 AM Posted 03/11/05 02:21 AM Is that the defilipo dump pipe.Dazza.
