  • Wanabe mechanical engineer
  • Member For: 20y 9m 20d
The DSC runs via input through the ABS system. It simply measures wheel speed in regards to the other 4 wheels and to the speed you were travelling at before a traction loss occured, as well as yaw and pitch.
It doesn't care if you have racing breaks on pizza cutter tyres, with 500kw, it will still do its job independantly of other modification.
DSC is controlled by the ABS unit and it does care if you are running pizza cutter tyres.The system is calibrated to allow for side wall deflection of the tyres when calculating the amount of intervention required to control the vehicle.
Yes, BUT, the system isn't built around the tyres. They have simply picked a value of deflection that will work with most tyres, even ones with stiff side walls or ones that feel like driving on soggy weet-bix....
  • Replies 52
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
lawsy unsure of the finer details as to how it works but fordtech is the smartest fordtech I know!!!
and he gets product training!!!!
  • Member For: 22y 1m 7d
<{POST_SNAPBACK}>
The system isn't built around the tyres but it is calibrated for them.And these parameters cannot be modified.You can reset tyre sizes in the PCM to whatever you like but you can't "Reflash" the ABS unit because it's a safety item.Hence they are calibrated to suit the tyres fitted at factory and any change in these(mainly profile height) will adversely affect the operation of the DSC.
Needless to say this won't stop people putting different wheels on their vehicles.All I'm saying is that it "will" affect the DSC system.
