  • Member For: 20y 11m 30d
Posted
Hey all,
Have a slight problem with my flasher. When I load the tunes my car will not go into cruise control in fifth gear. When I have it stock there is no problem. I have taken it back to ford and they said there is nothing wrong with it. Wondering if anyone has had a similar problem and if I could get my tuner replaced if that was the case.
Cheers
Posted
Hey all,
Cheers
<{POST_SNAPBACK}>
its not the box its the tune ive seen similar problems with cruise and also worse but it is the tunes in all the cases ive seen!!!
  • Member For: 23y 8m 28d
Posted
Wipdaddy, if this is the case then there is a simple fix. To rectify this you would need to read the processor code off the side of your engine management computer located in the engine bay. Its a four digit code on the little white sticker (the one with the bar code) and in the case of a 'T' would have something like A3YA, A3GC or similar on it in little letters. It would seem that you have a base software mismatch occurring which is affecting the cruise control, which can by quite easily fixed with a reflash of the Flasher unit itself.
So, give us a complete description of your car I.e. 03 XR6 T manual
and then the processor code, and I will personally look into it for you
  • 4 weeks later...
Posted
ok I have been back to the dealer who I bought the flash tuner of and he said I need to send it back to CAPA to get reflashed. Cool with me, but will it cost me anything and can I get the latest software loaded? Is the dealer just being lazy, cause I thought he should have send it back for me.
Regards Zane
