19/09/05 10:20 AM19/09/05 10:20 AM #1 Hey guys,I wanna do a few more mods to the xt, one being a change of differential gears. At the moment I have the stock base model diff (single wheel spinner) just wondering what would be the easiest way to get a better launch.. obviously a set of 4.11 diff gears would be ideal... but in my case what would be the cheapest and easiest eay to get a better launch maybe a 3.7 spline? Has anyone done this before? or is it purely a waste of time? I know its only an "XT" but I wanna be different to the average joe out there with an xt... if the diff doesnt work out im still dropping it from its 4WD height :DThanks in advance guysDave
21/09/05 11:04 AM21/09/05 11:04 AM #2 We have done only XR model cars and as far as I know tha XT series still uses the BW diff so there is a range of ratio options you can use, ratios such as 3.46,3.73,3.91which I believe could be fitted, call me on 0746613548, Mal Wood
21/09/05 11:27 AM21/09/05 11:27 AM #3 Author Hey thanks for the reply, I am actually in Mackay, QLD, I am wondering if you guys would supply the parts and I could get somone to fit them up this way? How much are the different gear ratios, and do they come with all the required parts?Cheers Dave
21/09/05 01:42 PM21/09/05 01:42 PM #4 We have done only XR model cars and as far as I know tha XT series still uses the BW diff so there is a range of ratio options you can use, ratios such as 3.46,3.73,3.91which I believe could be fitted, call me on 0746613548, Mal Wood<{POST_SNAPBACK}>Can a 3.91 ratio be fitted to a BA GT?CYA JEFF
21/09/05 02:34 PM21/09/05 02:34 PM #5 We have done only XR model cars and as far as I know tha XT series still uses the BW diff so there is a range of ratio options you can use, ratios such as 3.46,3.73,3.91which I believe could be fitted, call me on 0746613548, Mal Wood<{POST_SNAPBACK}>Can a 3.91 ratio be fitted to a BA GT?CYA JEFF <{POST_SNAPBACK}>Nope ... maybe one day. As yet 3.73 is the only available option.
22/09/05 07:17 AM22/09/05 07:17 AM #6 has anyone fitted a spool to an xr yet as I am thinking of doing this any info much apprectiated
