July 17, 200521 yr #11 I think they would get a US injector and make it fit the BA slot.. Looks like the 3 hole ones that were floating around a while ago, maybe they modify them to quads?? Cheap enough and @ 48Lbs, hell they'd supply some power.Nah, they are Delphi/LucasRob
July 17, 200521 yr #12 So what do you guys think about the option of getting a set of stock injectors drilled out and flow checked?
July 17, 200521 yr #13 So what do you guys think about the option of getting a set of stock injectors drilled out and flow checked?<{POST_SNAPBACK}>that's exactly what Nizpro are selling!!!From all accounts they work very well I believe. Edited July 17, 200521 yr by F6_Tornado
July 17, 200521 yr #14 So what do you guys think about the option of getting a set of stock injectors drilled out and flow checked?that's exactly what Nizpro are selling!!!From all accounts they work very well believe.I have Nizpro drilled injectors and am very happy with them.
July 19, 200521 yr #15 So what do you guys think about the option of getting a set of stock injectors drilled out and flow checked?that's exactly what Nizpro are selling!!!From all accounts they work very well believe.I have Nizpro drilled injectors and am very happy with them.So they look exactly as stock on the outside? I like the stealth look!
July 19, 200521 yr #16 just a quick Q, sorry if im off-topic.what KW @ the wheels does the standard fuel pump max out at?im getting a turbo ute next week and going to mod to about 280-300.
July 19, 200521 yr #17 315 kw upwards on our dyno mor for manuals 330 oddregardsdavid rosciokpm motorsport
July 20, 200521 yr #19 Hey all,Thanks for the input, now what I can gather is I have two options.1. Go with the tried and tested Bosch units, unused and straight out of the packaging.2. Take a chance with an apparent reputable workshop that have modified and tested there product, claiming the ablility to flow and feed up to 600hp+.What specific questions should I ask these guys, to be positively sure what they say is true but also safe.Hope to put this issues to rest, resting under the hood to make a fire breathing monster :devilflame: that devil himself would be proud of!!! Thanks,Darren. Edited July 20, 200521 yr by DARREN
July 20, 200521 yr #20 So what do you guys think about the option of getting a set of stock injectors drilled out and flow checked?that's exactly what Nizpro are selling!!!From all accounts they work very well believe.I have Nizpro drilled injectors and am very happy with them.So they look exactly as stock on the outside? I like the stealth look!Yep. I doubt you'd pick em.
