xrturb god bless my kids Member 611 Member For: 21y 2m 1d Gender: Male Location: claremont meadows, sydney Posted 19/05/05 10:55 PM Share Posted 19/05/05 10:55 PM in all fairness it is only at least two with the issue and it is not wide spead Link to comment https://www.fordxr6turbo.com/forum/topic/17721-edit-economy-the-facts/page/2/#findComment-254799 Share on other sites More sharing options...
Lawsy Wanabe mechanical engineer Donating Members 960 Member For: 20y 9m 9d Gender: Male Location: At the computer, obviously..... Posted 23/05/05 12:57 PM Share Posted 23/05/05 12:57 PM I'm sure you could just be really soft in your adjustments, like 14.8:1 clossed loop AFR. It might give you another 10k's in a tank, you never know.....I'm sure that would have barely any effect on the temps as well......Meh, I'm just spamming. Link to comment https://www.fordxr6turbo.com/forum/topic/17721-edit-economy-the-facts/page/2/#findComment-255968 Share on other sites More sharing options...
Guest Guests Posted 23/05/05 01:16 PM Share Posted 23/05/05 01:16 PM I'm sure you could just be really soft in your adjustments, like 14.8:1 clossed loop AFR. It might give you another 10k's in a tank, you never know.....I'm sure that would have barely any effect on the temps as well......Meh, I'm just spamming.<{POST_SNAPBACK}>that is correct lawsy it is just that some times we comand 14.8/1.1 but get 14.5/.99 this is not the edit but the pcm or for that matter the test equipment etc!!! Link to comment https://www.fordxr6turbo.com/forum/topic/17721-edit-economy-the-facts/page/2/#findComment-255969 Share on other sites More sharing options...
Crazy F6 Member 61 Member For: 20y 5m 22d Location: 370KW Country Posted 24/05/05 07:37 AM Share Posted 24/05/05 07:37 AM (edited) So is what you are saying street tuner is edit is safer then piggybacks,Why I am asking this is I drive my car hard all the time all day every day so if I leave my piggyback on my engine is it going to be stuffed. So is my engine life going to be better with a edit or a piggyback??? Edited 24/05/05 07:50 AM by Crazy F6 Link to comment https://www.fordxr6turbo.com/forum/topic/17721-edit-economy-the-facts/page/2/#findComment-256093 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 2m Gender: Male Location: Victoria Posted 24/05/05 07:40 AM Share Posted 24/05/05 07:40 AM So is what you are saying street tuner is edit is safer then piggybacks,Why I am asking this is I drive my car hard all the time all day every day so if I leave my piggyback on my engine is it going to be stuffed at how many kays??????I think that's a how longs a piece of string type of question. Link to comment https://www.fordxr6turbo.com/forum/topic/17721-edit-economy-the-facts/page/2/#findComment-256094 Share on other sites More sharing options...
xlnt6 Donating Members 350 Member For: 20y 8m 24d Gender: Male Location: Melbourne, Victoria Posted 24/05/05 11:50 AM Share Posted 24/05/05 11:50 AM Street Tuner,That's great info, appreciate you sharing that with us. I've had the Edit fitted for several weeks now, and after initial tuning Simon@Nizpro was able to get much more mid-range power/torque from the engine vs using the TSI Pro Sequential piggyback I had previously.As you cover well in your post, I was told / read that removing the "torque limiting" constraints of the Edit were somewhat responsible for the improvement. Now I can see this isn't quite true, although the overall impact is similar. What my thread shows:http://www.fordxr6turbo.com/forum/index.php?showtopic=17416is that at the same boost or less boost (see high RPM) the edit out performed the TSI as well. Is this a similar reason as described, or is it just maintaining a better AFR/timing combo to produce better results ? I'm interested in hearing the technical whys and wherefores for this.I have noted that with a combo of town/highway driving I used to regularly get between 510-530km from a tank, and now I get 480-510km from a tank with Edit (a change of around 10%). I can live with that, as I wouldn't want to go back in performance for the sake of a bit more fuel. After all, we don't want any of those oil sheiks to go hungry now do we.....CheersRobin. Link to comment https://www.fordxr6turbo.com/forum/topic/17721-edit-economy-the-facts/page/2/#findComment-256202 Share on other sites More sharing options...
Lawsy Wanabe mechanical engineer Donating Members 960 Member For: 20y 9m 9d Gender: Male Location: At the computer, obviously..... Posted 25/05/05 04:37 AM Share Posted 25/05/05 04:37 AM I'm sure you could just be really soft in your adjustments, like 14.8:1 clossed loop AFR. It might give you another 10k's in a tank, you never know.....I'm sure that would have barely any effect on the temps as well......Meh, I'm just spamming.that is correct lawsy it is just that some times we comand 14.8/1.1 but get 14.5/.99 this is not the edit but the pcm or for that matter the test equipment etc!!!Oh, I see.... So would it be safe to say that you could just play with it untill you knew that you were going to get, say, just under 15:1 for less than 2300 rpm (about 120km/h ish) so that, without any real nasty increases in heat, you could get the benefit of the leaner mix?It would be interesting to see what you guys can come up with as a very mild and soft method of running a leaner mix without having ANY adverse affects on the engine. Really interesting indeed..... Link to comment https://www.fordxr6turbo.com/forum/topic/17721-edit-economy-the-facts/page/2/#findComment-256373 Share on other sites More sharing options...
Guest Guests Posted 25/05/05 05:39 AM Share Posted 25/05/05 05:39 AM I'm sure you could just be really soft in your adjustments, like 14.8:1 clossed loop AFR. It might give you another 10k's in a tank, you never know.....I'm sure that would have barely any effect on the temps as well......Meh, I'm just spamming.<{POST_SNAPBACK}>that is correct lawsy it is just that some times we comand 14.8/1.1 but get 14.5/.99 this is not the edit but the pcm or for that matter the test equipment etc!!!<{POST_SNAPBACK}>Oh, I see.... So would it be safe to say that you could just play with it untill you knew that you were going to get, say, just under 15:1 for less than 2300 rpm (about 120km/h ish) so that, without any real nasty increases in heat, you could get the benefit of the leaner mix?It would be interesting to see what you guys can come up with as a very mild and soft method of running a leaner mix without having ANY adverse affects on the engine. Really interesting indeed.....<{POST_SNAPBACK}>essentially yes you can acheive 15:1 afr with a few atempts Link to comment https://www.fordxr6turbo.com/forum/topic/17721-edit-economy-the-facts/page/2/#findComment-256391 Share on other sites More sharing options...
