May 18, 200521 yr #1 Hi just wondering if you can install the Auxiliary Audio Plug-in yourself or do you have to get ford to do it ?Cheers in advance.
May 18, 200521 yr #2 You can install it yourself.There is a user called Aaron with an article in his sig explaining how to do it all. to the forum too
May 18, 200521 yr #3 You are better off with the FM transmitter as it gives better sound quality than the crappy aux port.
May 19, 200521 yr #4 Thanx guys I think I will stick with the Itrip saves some mucking around and $35
May 19, 200521 yr #5 We use the DIY input (http://photos.ausmicro.net/BA_Falcon/AUX_Audio.pdf) and a Belkin car traver adapter thingo. It gives the higher signal level and power tot he iPod meaning very little hum/buzz etcA.
