  • Member For: 15y 10m 27d
I've been told that a car that surges is usually running lean, I put my surging down to the car going into closed loop mode and leaning the mix back which is what they suppose to do when coasting or cruising to get better mileage, mine also surges around 2000-2200 rpm which when cruising in 6th gear is around 100-110 " highway speed" kinda makes sense?
  • Member For: 13y 11m 7d
does seem to make sense im hoping a retune may also fix my problem because it only started doing it the day I picked it up from the tuner. fingers crossed they can sort it out while its getting the surge tank put in id say it will need a retune after that anyways
