October 6, 200422 yr #21 HAD A 3 '' SYSTEM PUT ON MINE YESTERDAY MANDREL BENT REPLACED EVERYTHING FROM THE DUMP PIPE BACK SOUNDS AWESOME PRETTY CONFIDENT THAT IT IS GOING BETTER AS WELL. I WILL KNOW NEXT TIME I GO TO THE DRAGS
October 6, 200422 yr #22 HAD A 3 '' SYSTEM PUT ON MINE YESTERDAY MANDREL BENT REPLACED EVERYTHING FROM THE DUMP PIPE BACK SOUNDS AWESOME PRETTY CONFIDENT THAT IT IS GOING BETTER AS WELL. I WILL KNOW NEXT TIME I GO TO THE DRAGS How much??? and where did you get it?Oh and Dazza.
October 6, 200422 yr #23 HAD A 3 '' SYSTEM PUT ON MINE YESTERDAY MANDREL BENT REPLACED EVERYTHING FROM THE DUMP PIPE BACK SOUNDS AWESOME PRETTY CONFIDENT THAT IT IS GOING BETTER AS WELL. I WILL KNOW NEXT TIME I GO TO THE DRAGSHow much??? and where did you get it?Oh and Dazza. and turn OFF your caps lock while your at it...
October 6, 200422 yr #24 Which dump pipe did you get gameover,the pollished alloy one in the other thread???Oh and vik
October 6, 200422 yr #25 All you guys sleep thru primary school maths?Dont you remember how to calculate the area of a circle?Area is calculated by pi R squared. Diameter/2 = radius2.25" / 2 = 1.125 this is the radius for each standard pipe.3 / 2 = 1.5 this is radius of biggus dickus zorst.pi = 3.141592654so standard is pi * (1.125 * 1.125) = 3.976 times 2 for dual pipes = 7.952" sq3 inch single is pi (1.5 * 1.5) = 7.068" sqSo the standard system has a greater cross sectional area than a single 3".
October 6, 200422 yr #26 All you guys sleep thru primary school maths?Dont you remember how to calculate the area of a circle?Area is calculated by pi R squared. Diameter/2 = radius2.25" / 2 = 1.125 this is the radius for each standard pipe.3 / 2 = 1.5 this is radius of biggus dickus zorst.pi = 3.141592654so standard is pi * (1.125 * 1.125) = 3.976 times 2 for dual pipes = 7.952" sq3 inch single is pi (1.5 * 1.5) = 7.068" sqSo the standard system has a greater cross sectional area than a single 3". Genius in the midst. :lol: Dazza.
