turb06 Dark Knight Mafia Member No. - 666 Member 3,667 Member For: 22y 3m Location: Toowoomba Posted 23/07/04 12:55 PM Share Posted 23/07/04 12:55 PM After having my car played with by ford, I am noticing my BOV is no longer fluttering, I think it is clogged with paper still. I am 80% sure I know where the BOV is I would like someone in the know to confirm that 20%.So any pics would be nice. Link to comment https://www.fordxr6turbo.com/forum/topic/11965-photo-of-factory-bov/ Share on other sites More sharing options...
saleen Big Gun Donating Members 4,170 Member For: 22y 7m 15d Gender: Male Location: NSW Posted 23/07/04 01:55 PM Share Posted 23/07/04 01:55 PM Here ya go................... Link to comment https://www.fordxr6turbo.com/forum/topic/11965-photo-of-factory-bov/#findComment-146327 Share on other sites More sharing options...
Mario Mendoza Member 82 Member For: 21y 1m 28d Location: Blue Mountains Posted 23/07/04 02:29 PM Share Posted 23/07/04 02:29 PM Prbly not really a problem with your BOV if it no longer makes a fluttering noise, as a car with an efficient BOV should not flutter.The fluttering sound is caused by your BOV not corrretly venting the air (atmo or not) The sound comes from the Turbo intake and is called compressor surge. It's made when air is forced back into the turbo cause it's got no-where else to go when you shut the gas off. You might receive a slight amount of flutter periodically as the BOV piston is actuated, but shouldn't be that noticeable...So by the sounds of it they fixed your BOV I'm told that compressor surge is actually bad for a turbo, kinda the opposite of what you should be doing to a turbo, as the air suddenly slows the compressor down as it's forced back through it each time your're on/off the gas.So I'm told........... Link to comment https://www.fordxr6turbo.com/forum/topic/11965-photo-of-factory-bov/#findComment-146332 Share on other sites More sharing options...
turb06 Dark Knight Mafia Member No. - 666 Member 3,667 Member For: 22y 3m Location: Toowoomba Posted 23/07/04 02:54 PM Author Share Posted 23/07/04 02:54 PM Prbly not really a problem with your BOV if it no longer makes a fluttering noise, as a car with an efficient BOV should not flutter.The fluttering sound is caused by your BOV not corrretly venting the air (atmo or not) The sound comes from the Turbo intake and is called compressor surge. It's made when air is forced back into the turbo cause it's got no-where else to go when you shut the gas off. You might receive a slight amount of flutter periodically as the BOV piston is actuated, but shouldn't be that noticeable...So by the sounds of it they fixed your BOV I'm told that compressor surge is actually bad for a turbo, kinda the opposite of what you should be doing to a turbo, as the air suddenly slows the compressor down as it's forced back through it each time your're on/off the gas.So I'm told........... I dont understand how a BOV can vent air silently, I have never seen or heard a silent BOV before, even the majority of plumb back BOV's I have heard have all made a noise, and some quite a loud one. Saleen - Thanks mate, it seems my 80% assumption was correct, but now I am certain. Link to comment https://www.fordxr6turbo.com/forum/topic/11965-photo-of-factory-bov/#findComment-146344 Share on other sites More sharing options...
YOOT Member 1,201 Member For: 21y 11m 6d Location: Birkdale Posted 23/07/04 10:12 PM Share Posted 23/07/04 10:12 PM I think you'll find the plumb back is more efficient because it helps spool the turbo faster by dumping a heap of air at hi velocity back through it. And yes the flutter is the noise of the air hitting the turbo's impella blades, not the valve itself. The valve should be silent, and that flutter we all love to hear is the turbulent are entering the turbo. Two separate things. Link to comment https://www.fordxr6turbo.com/forum/topic/11965-photo-of-factory-bov/#findComment-146373 Share on other sites More sharing options...
turb06 Dark Knight Mafia Member No. - 666 Member 3,667 Member For: 22y 3m Location: Toowoomba Posted 24/07/04 01:20 AM Author Share Posted 24/07/04 01:20 AM I think you'll find the plumb back is more efficient because it helps spool the turbo faster by dumping a heap of air at hi velocity back through it. And yes the flutter is the noise of the air hitting the turbo's impella blades, not the valve itself. The valve should be silent, and that flutter we all love to hear is the turbulent are entering the turbo. Two separate things. Ok, so why would ford release a car that doesnt have a BOV that functions properly, and it will only funtion properly after it has been tampered with?Something doesnt seem to add up to me. Link to comment https://www.fordxr6turbo.com/forum/topic/11965-photo-of-factory-bov/#findComment-146403 Share on other sites More sharing options...
HUSTLER Member 663 Member For: 21y 9m 5d Location: Broken Hill Posted 24/07/04 03:24 AM Share Posted 24/07/04 03:24 AM My BOV from factory leaked like a siv!! once I changed the BOV to an after market one, I gained 11kw on the dyno!! It was tuned with the leakey one and then withoutout, within two days of each other and that was the diff!! seems astonishing to me the diff it made!! Also the flutter that I used to get pretty loudly has now pretty much completly ceased!Point here being, ford do send out some stuffed BOV from factory! Link to comment https://www.fordxr6turbo.com/forum/topic/11965-photo-of-factory-bov/#findComment-146422 Share on other sites More sharing options...
YOOT Member 1,201 Member For: 21y 11m 6d Location: Birkdale Posted 24/07/04 03:29 AM Share Posted 24/07/04 03:29 AM I think you'll find the plumb back is more efficient because it helps spool the turbo faster by dumping a heap of air at hi velocity back through it. And yes the flutter is the noise of the air hitting the turbo's impella blades, not the valve itself. The valve should be silent, and that flutter we all love to hear is the turbulent are entering the turbo. Two separate things.Ok, so why would ford release a car that doesnt have a BOV that functions properly, and it will only funtion properly after it has been tampered with?Something doesnt seem to add up to me. It doesn't funtion preperly, in fact it operates in reverse to every other BOV in every other Turbo car. Its generally a much better design, I don't know the fine details, but I could get them if you really want. Still, wasn't your original question regarding the paper from your dealer mishap? Link to comment https://www.fordxr6turbo.com/forum/topic/11965-photo-of-factory-bov/#findComment-146425 Share on other sites More sharing options...
XR6ISM ASHA - Anti Stooge Hunter Association Member 535 Member For: 21y 11m 14d Location: Sydney Bronx :) Posted 24/07/04 05:25 AM Share Posted 24/07/04 05:25 AM I think you'll find the plumb back is more efficient because it helps spool the turbo faster by dumping a heap of air at hi velocity back through it. And yes the flutter is the noise of the air hitting the turbo's impella blades, not the valve itself. The valve should be silent, and that flutter we all love to hear is the turbulent are entering the turbo. Two separate things. I always thought that realising to atmo was more efficient because it allows your turbo to free spin whilst your changing gears, hence, less spool up time when you hit the gas again !! Link to comment https://www.fordxr6turbo.com/forum/topic/11965-photo-of-factory-bov/#findComment-146443 Share on other sites More sharing options...
Chris xr6 Member 376 Member For: 21y 1m 25d Location: Shire Posted 24/07/04 05:49 AM Share Posted 24/07/04 05:49 AM A plumb back bov will route the excess air back pre turbo and after the MAF if the car has one which the T's dont Link to comment https://www.fordxr6turbo.com/forum/topic/11965-photo-of-factory-bov/#findComment-146449 Share on other sites More sharing options...
