08/06/04 10:12 AM08/06/04 10:12 AM #11 The recall they would be refering to would be PRGC 277 regarding the crankshaft timing chain sprocket.During testing if the sprocket is faulty the teeth break of the crankshaft tone wheel(the sprocket and tone wheel are one assy)Don't quite understand why they would break any other bolts while testing though.You only need to remove the electric fans,an idler pulley and the crank angle sensor to do the test.
09/06/04 04:07 AM09/06/04 04:07 AM #12 You only need to remove the electric fans,an idler pulley and the crank angle sensor to do the test. That all, I'll do it myself this arvo Scotty CCC
