Search the Community
Showing results for tags 'map2 sensor fault code'.
  • Search By Tags
  • Search By Author
  • Vehicle Discussions
    • XR6 Turbo
    • FPV & Tickford
    • XR8 & GT
    • G6E Turbo
    • Falcon Utes (UTEopia)
    • Territory Turbo
    • Euro Turbo Fords (Focus & Mondeo XR5)
    • Ford Discussion
    • Ford 4.0L N/A
    • Engine Conversions & Swaps
  • Community Zone
    • General Automotive Talk
    • Off-Topic
    • Media & Projects
    • Track & Strip Racing
    • Photo Gallery
  • Tech Workshops
    • General Tech
    • Audio & Visual
    • Interior & Exterior Workshop
    • Exhaust Workshop
    • Electrics Workshop
    • Wheels and Tyres
    • Suspension and Handling
    • Brakes
    • Driveline Workshop
    • Forced Induction Workshop
    • Engine Management & Fuel Systems
    • Engine Workshop
    • High Power Builds (300+ Club)
  • Regional Events
    • General Discussion
    • East Coast (NSW, ACT, QLD)
    • Southern States (VIC, SA, TAS)
    • Western & Northern Australia (WA, NT)
    • New Zealand
  • Buy & Sell
    • Classifieds & Group Buys
  • The Site
    • Site Announcements
    • Site Support & Feedback
Product Groups
  • Advertisements
  • DM Packages
  • Merchandise
    • Stickers
    • Key Rings
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Found 1 result
  1. Hi , I have a problem with my MAP sensor Volt reading. A fault code inspired me to get to the bottom of this. Fault code below :- : P0108 - BARO Sensor : Sensor operating : * VREF shorted to : - VREF should be less : : High Voltage Detected : voltage is greater : VWPR : than 6.0 volts. PID : : : than 5.0 volts (VREF), : * BARO signal shorted : reading is in : : : as a result it failed : to VPWR : frequency : : : above maximum : * Damaged BARO sensor : : : allowable calibrated : * Damaged PCM : : : parameter. : I originally thought MAP2 Sensor but seems they are $150+ dollars I thought I would start with checking Volt readings threw the 4 wires connecting to MAP2 switch. I refereed to Repair manual for STD volt reading for test. When the car is cold it should read 5960 Resistance Ohms & 4.3 Volts. Green wire reads 5.5 Volts Brown Wire Reads 5.0 Grey Wire Reads 2.0 Grey Wire Reads 2.2 What is causing this , what do I need to inspect next... Help Kind Regards Dan
