  • Into the laaaake
  • Member For: 19y 3m 11d
Posted (edited)
Ive seen a few guys mount there surge tanks in between the ute liner and the outer rear quarter panel, just above the fuel filler neck. Also seen the process west one on the chassis rail (though it looks like a small capacity) Edit: 1.85L in capacity seems ok.
I was intending on just using the stock pump to pump into the tank and then a 044 to the engine.
I wont be seeing the drag strip or circut and will probably never hold it at WOT for a long period of time. But I want to fit a tank to be safe.
Any other ideas on placement of the tank? Will an installation like this require the fitment of a one way valve to retain fuel line pressure?
Edited by hanra
  • Member For: 19y 6m 12d
Posted
I did the same,had my ute on a hoist and I looked at several different options and I decided on the process west for ease of fitment.
by the time you stuff around making a setup you could have just bought one and be driving already.
  • Into the laaaake
Posted
True, so there is no where else under the tray area? My budget dosnt allow for a $600 tank.
Posted
well there is heaps of room up near the filler neck, but you will have to run the lines back from the engine bay unless you want to remove the tank to get at the fittings on the top of it.
then you need to make the tank,mount it solid(there isnt much to bolt to) and run the fuel lines back to the engine bay.
I am a tig welder and I could have made something up for next to nothing but when I seriously looked at the system I was going to end up with it just wasnt as good as the process west design.
to me the design of his tanks is very simple and well worth the cashish
  • Into the laaaake
Posted
Certainly, the PW system is a great idea!!! Seems a few guys here have just removed the ute liner, then drilled out some spot welds and removed a panel to gain access to the top of the tank. Theres plently of tanks on Ebay for bugger all which im sure I can get to fit/mount.
  • Mmmmm......BOOST
  • Member For: 19y 4m 28d
Posted
time/money it's all relavent just depends what you got more of
  • Into the laaaake
Posted
Ive got more time then money, but more dollars then sense...
  • Into the laaaake
Posted (edited)
Pulled the tub liner out today and sussed things out. I think ill mount it where others have, in between the liner and rear skin.
Edited by hanra
