exahsix Member 296 Member For: 20y 11m 21d Location: Monterey, NSW Posted 13/12/06 09:10 AM Posted 13/12/06 09:10 AM Hey peoples, I finished my plenum changeover (got one with the throttle body mount tigged into the reverse position) and it kicks ass. Everyone should have one.Got the top plenum lying around and a spare throttle body. What about this - making a blanking plate to block off the original throttle body mount, sealed up with gasket goo and the original 4 bolts. This could even be made to look nice with some Ford badging.Then on the other side, how about using the flat area of the casting to mount the throttle body? Use a holesaw to cut the correct size hole (3" I think) and then drill and tap 4 bolt holes into it to hold the throttle body on. Of course a thick gasket or O ring solution would be needed to seal it properly.Anyone tried it? Thoughts? Pic attached.
Dr Concrete Member 69 Member For: 21y 2m 17d Location: Adelaide Posted 13/12/06 10:13 AM Posted 13/12/06 10:13 AM I guess everyone who owns a T thought of this at one stage. Looks like a better idea than the factory location. Maybe there should be an transition adapter bolted between the throttle body and the upper plenum? Easier to bolt up and seal than to weld for us home tuners.
RAP1D Member Legacy Donating Member 3,739 Member For: 20y 4m 1d Gender: Male Location: Sydney NSW Posted 13/12/06 10:17 AM Posted 13/12/06 10:17 AM Hey any pics of the one you have on the car? I'm keen to do it too
exahsix Member 296 Member For: 20y 11m 21d Location: Monterey, NSW Posted 13/12/06 10:40 AM Author Posted 13/12/06 10:40 AM Hey any pics of the one you have on the car? I'm keen to do it too←Yeah here it is before I bolted up the cooler pipe to it. Was a great improvement.manifold.bmp.bmp
RAP1D Member Legacy Donating Member 3,739 Member For: 20y 4m 1d Gender: Male Location: Sydney NSW Posted 13/12/06 10:40 AM Posted 13/12/06 10:40 AM (edited) ah coolSo, another way could be to, as you said, block the hole with a plate and cut the hole on the otherside and weld a 3in pipe directly to it... might be a bit rough on the inside though.Whats the casting like on the inside ( flipped over ) could we get in there with the die grinder and make it smoother and maybe be gain some volume?I'm off to the wreckers... an AU top section should be the same? Edited 13/12/06 10:41 AM by RAP1D
exahsix Member 296 Member For: 20y 11m 21d Location: Monterey, NSW Posted 13/12/06 08:06 PM Author Posted 13/12/06 08:06 PM Casting is pretty good on the inside - and could definately be attacked with a die grinder. I was trying to find some solutions that didn't involve TIG welding - for the home enthusiast.Yeah an AU top plenum will do it.
apache_dj Member 145 Member For: 21y 3m 19d Location: Auckland NZ Posted 02/01/07 08:09 AM Posted 02/01/07 08:09 AM Hi Guys, I tried this as well using an AU plenum, the bolts that mount the throttle to the plenum are diferent size on the AU plenum, from memory they are 8mm and the BA throttle mounts up to the plenum using longer 6mm bolts. I hope this helps I never noticed until I was trying to mount the BA throttle body onto the completed project.
BFHOON Legacy Donating Member 1,932 Member For: 20y 5m 27d Gender: Male Location: nsw Posted 02/01/07 08:29 AM Posted 02/01/07 08:29 AM Casting is pretty good on the inside - and could definately be attacked with a die grinder. I was trying to find some solutions that didn't involve TIG welding - for the home enthusiast.Yeah an AU top plenum will do it.←I was thinking about having mine extrusion honed top and bottom.what do u guys think
BFHOON Legacy Donating Member 1,932 Member For: 20y 5m 27d Gender: Male Location: nsw Posted 02/01/07 08:32 AM Posted 02/01/07 08:32 AM oh year.that looks sweet mate.
RAP1D Member Legacy Donating Member 3,739 Member For: 20y 4m 1d Gender: Male Location: Sydney NSW Posted 02/01/07 08:59 AM Posted 02/01/07 08:59 AM that's gonna give it more volume, good idea dude
