Falcon Oath New Member 4 Member For: 6y 5m 5d Posted 21/11/17 11:32 AM Share Posted 21/11/17 11:32 AM So my BA XR6 Turbo, suddenly dropped boost pressure from 10psi to 4psi, ive been running a Gizzmo Electonic Boost controller, so naturally thought it was the Gizzmo solenoid had packed up, so swapped it back to standard boost control solenoid, but still no good, have since tried another known good solenoid, still no luck, it's plumbed up correctly, also has a brand new aftermarket plumb back BOV, setup correctly, and not leaking, so that also eliminates that. I need some guidance Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,129 Member For: 9y 2m 28d Gender: Male Location: South Australia Posted 21/11/17 11:35 AM Share Posted 21/11/17 11:35 AM (edited) Busted cooler piping, probably the rubber bit attached to the throttle body. Edited 21/11/17 11:36 AM by Puffwagon Cos Link to comment Share on other sites More sharing options...
Falcon Oath New Member 4 Member For: 6y 5m 5d Posted 21/11/17 12:19 PM Author Share Posted 21/11/17 12:19 PM Doesn't sound like a boost leak though ? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,129 Member For: 9y 2m 28d Gender: Male Location: South Australia Posted 21/11/17 12:21 PM Share Posted 21/11/17 12:21 PM It might not be but it can't hurt to check. When mine broke it lost boost pressure and didn't make any noise. Link to comment Share on other sites More sharing options...
Falcon Oath New Member 4 Member For: 6y 5m 5d Posted 21/11/17 09:52 PM Author Share Posted 21/11/17 09:52 PM Yeah I'll have a check for peace of mind, I've also tried re loading the tune and no luck with that, I'm just leaning towards wastegate actuator now, but usually when they go it's the diaphragm and they over boost not under boost. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,129 Member For: 9y 2m 28d Gender: Male Location: South Australia Posted 21/11/17 10:07 PM Share Posted 21/11/17 10:07 PM I'd be looking for a boost leak or an open solenoid if it spools normally but only makes 4 psi. With cars and internet diagnosis it could always be something less obvious. Link to comment Share on other sites More sharing options...
Falcon Oath New Member 4 Member For: 6y 5m 5d Posted 21/11/17 10:13 PM Author Share Posted 21/11/17 10:13 PM Tried 3 different solenoids, so unless it's the ECU holding it open I'd think it's not that, must be a boost leak then Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,129 Member For: 9y 2m 28d Gender: Male Location: South Australia Posted 21/11/17 10:26 PM Share Posted 21/11/17 10:26 PM Would seem like that based from what I know about it but keep an open mind for other possibilities. Eg: It could be a wiring issue rather than the ecu holding it open for whatever reason if it is solenoid related. Link to comment Share on other sites More sharing options...
