  • Member For: 2y 14d
Hi, I'm sorry if this is long winded explanation, but I want to get all the info out.
BA xr6 turbo ute 2005 6 speed manual. I replaced the fuel pump with a 525ltr in a larger FG bucket
Ran a fused 10g wire direct to battery and second relay to trigger from factory relay. Tested pump and started car fine, idled for approx half hour and switched it off, all was good. Disconnected battery to do some head unit work and when I reconnected the unit, the fuel pump now does not trigger.
I checked power to relay at ignition is fine. Jumped relay and still no power.
Inertia switch is getting power at ignition. Jumped Inertia switch and still no power.
So something is wrong somewhere between Inertia switch and pump?
When I jump the second relay that I installed, the pump runs fine
All fuses are good
Factory relay is good
Secondary relay is good
Pump is good
Inertia switch is good
Question is, does wiring go direct from Inertia switch to pump? Or is there another break between?
Pulling my hair out
Thanks in advance
https://www.fordxr6turbo.com/forum/topic/97281-fuel-pump-power-loss/
