QIK06T Member 39 Member For: 10y 10m 23d Gender: Male Posted 16/12/15 09:55 AM Share Posted 16/12/15 09:55 AM Hey fellas got a problem.Was driving home in my FG F6 on the highway today when the DSC fault came up. Then started the car at home later and the DSC and ABS fault came on. When sitting in the car at idle I can now hear a noise that seems to be coming from under the car but its not too loud that you can hear it from outside. Haven't changed tyres or done anything recently. However I must note that there was heavy rain in sydney today if that has anything to do with it.Is this a common fault. Any fixes?Sent from my SM-G925I using Tapatalk Link to comment https://www.fordxr6turbo.com/forum/topic/91495-dsc-and-abs-fault/ Share on other sites More sharing options...
jabtronic Member 70 Member For: 13y 23d Posted 16/12/15 10:44 PM Share Posted 16/12/15 10:44 PM When those 2 errors occasionally came up for me it took me months trying to figure out the problem It was a new brake switch (above brake pedal) that fixed it. It may not be the problem for you but they're very easy to swap out, if you can borrow one off someone Link to comment https://www.fordxr6turbo.com/forum/topic/91495-dsc-and-abs-fault/#findComment-1573972 Share on other sites More sharing options...
QIK06T Member 39 Member For: 10y 10m 23d Gender: Male Posted 17/12/15 12:03 AM Author Share Posted 17/12/15 12:03 AM I couldn't see any fluid in the mastery cylinder. I opened it and ask I could see is 2 rubber boots. I think one of my brake lines has come loose. Will investigate it on the weekend. Sent from my SM-G925I using Tapatalk Link to comment https://www.fordxr6turbo.com/forum/topic/91495-dsc-and-abs-fault/#findComment-1573979 Share on other sites More sharing options...
QIK06T Member 39 Member For: 10y 10m 23d Gender: Male Posted 19/12/15 11:37 PM Author Share Posted 19/12/15 11:37 PM (edited) Just to conclude. The fluid was not leaking so I went straight to Ford and got the switch for $29 and issue resolved surprisinglySent from my SM-G925I using Tapatalk Edited 19/12/15 11:38 PM by QIK06T 2 Link to comment https://www.fordxr6turbo.com/forum/topic/91495-dsc-and-abs-fault/#findComment-1574240 Share on other sites More sharing options...
