05/02/04 01:00 AM05/02/04 01:00 AM #11 Author Back from Service.Water in footwell was caused by blocked drain in fan unit, caused by leaves and stuff dropping into unit from fresh air vents. my fault I didnt keep it clean.Idle problem ...new software...didnt fix itDiff ok for now.Low power... seems to be ok they can add more if I wish Also oil leak around the turbo return pipe fixed.Craig
11/02/04 06:52 AM11/02/04 06:52 AM #12 Had the glass panels replaced yesterday only to find more leaks this morning after rain last night!! Straight into Ford and they blame glass ... Over to Windscreen O'Brien ... and after 2 guys crawl all over my seats and supercab we find the joint leaking between the roof and the side panel (under the black plastic strip) between the spot welds. Little bit shoddy there and I am not happy with the fingerprints and knocks all over my interior now after ripping out all of the interior lining. 3 hours of my time wasted. Glad they found the leak I guess. They will fix it next week just with a bead of sealer and thick clear coat ... dunno about the quality of that yet...B
