  • Member For: 11y 8m 9d
so im going to turbo my na dont say just buy a turbo I dont wanna here it I have an xr6 na with wiring what do I need to do ? change out the whole loom or do I need just a certain piece that will plug in can somone please help me out on this
https://www.fordxr6turbo.com/forum/topic/87529-na-to-turbo-wiring-qs/
  • Member For: 18y 1m 26d
Your NA Engine will need new pistons [ to lower the compression ] and stronger conrods.
New PCM. New exhaust manifold, Oil and water supply to and from turbo unit. New Engine mounts. X-Over unit and Intercooler... plus all the Air intake piping. New MAP sensor. New Water Pump. New Spark Plugs.... And and and.................................
Edited by f-wolf
  • Member For: 11y 6m 12d
Am doing am full conversion at the moment, get a fuse box wiring loom from a wreckers (basically replaces the whole drivers side loom) it's indentical to the n/a but it has boost soleniod wiring, Easy job knocked it over in about 3 hours! You will even be able to run your car as is until your conversion is complete! Ps you will need twin themo fan set up.
