November 26, 201312 yr #1 Just wondering guys I just bought a new turbo oil feed line, braided stainless one, do I need a tee near the oil filter at the bottom of the engine, because it feels like the standard line is welded in maybe. Cheers
November 26, 201312 yr #2 You need 23mm deep socket and 19mm deep socket I think it was! you just pull it out the oil pressure switch and then pull out the next peice which will remove the oil feed but you will need two new copper washers to reinstall I'll double check the socket sizes tommorrow Once you have sockets and get the car In the air you will understand what I mean
