February 3, 201313 yr #1 wired in my PW fuel pump and I have a problem, car runs and works but the fuel pump runs non stop all the time, even on accessories. I have wired it how the instructions say pink wire to pink wire. I wired the singal wire of the new relay (small pink wire) into the large pink wire of the existing relay (signal wire). is this right or is the sigal of the new suposed to go into the power out of the old heading to the old pump Edited February 3, 201313 yr by Ribby
February 3, 201313 yr #3 What do you mean it runs all the time only with the ignition on ? But in all positions but it doesn't run when the key is out ?
February 3, 201313 yr #4 Author when car is switched onto accessories it starts pumping and then when started it just runs non stop
February 3, 201313 yr #5 Author k well bit the bullet and re wired the relay for anyone who wanted to know when you put the new relay in the new relay switch wire goes into the old power wire not the old switch wire. well I know now and can only learn by doing
