January 21, 201313 yr #1 Chaps, where can I source an F6 snorkel from that I read a bit about on here? And are they a straight fit for the FG XR6T?
January 21, 201313 yr #2 In the FG the entire intake is identical in the F6 and XR6T. The 5.4L V8 FGs have a different snorkel and lower half on air box.If you want more induction noise look at Growler, Herrod, Process West, Plazmaman etc for replacement intakes with big pod filters. I got a Growler on mine and it makes a nice difference to induction noise and much better throttle response also..........but everyone will say to go turbo side if you want to change intake
January 22, 201313 yr #3 Author I can't justify $400 odd just for a new air box. Was looking for a cheaper way of flowing a bit more air
January 22, 201313 yr #4 In that case just change to a K&N panel filter and drill a couple of 60-80mm holes in the front of your current lower half of airbox.The only larger snorkel you will get for an FG is the V8 one for a 5.4L and they require a new lower half of airbox and event they are a couple of hundred.
January 22, 201313 yr #5 Author OK cheers mate. Already got the k&n so might look at fabbing something up myself
