January 4, 201313 yr #1 When I first start the car it gurgles, like air is trapped in the cooling system. it stops after a bit of driving.has any one had this before? I did some research and apparently it is common for air to get caught in the heater core, so my plan is to cycle the heater on and off over a couple of drives, would this fix it?cheersedit: car doesn't over heat or heat up unusually quick and has more than enough in the coolant bottle. Edited January 4, 201313 yr by ledoff
January 4, 201313 yr #2 Yes common, cycling the heater on off will do sweet fa unless its bf or earlier as after that they dont hae a heater tap, even early ones that the heater tap leaked on had it deleted by a superseded part. Remove your header tank cap and run it for half hour or so on flat ground, give it a few revs everynow and then, normally clears it up
January 4, 201313 yr #3 Author Yes common, cycling the heater on off will do sweet fa unless its bf or earlier as after that they dont hae a heater tap, even early ones that the heater tap leaked on had it deleted by a superseded part. Remove your header tank cap and run it for half hour or so on flat ground, give it a few revs everynow and then, normally clears it up sweet thanks for the quick reply, ill give that a go tomorrow. much appreciated.Jack
