October 18, 201214 yr #1 Hello got a bf2 f6 start of the year and notice a ticking noise from back end jacked up back an turn wheels you can hear every rotation a tick tick had Ford do inspectionOver car said rear diff bush gone went to family mechanic starting taking tailshaft off notice lose bolts done them up was better but not 100 % drove work today noisy again anybody had this problem headbutting things about spelling getting my drink on to Carm nerves. Sent from my BlackBerry 9800 using Tapatalk
October 18, 201214 yr #3 Author Nah you can put the clutch in cruzin and still there I notice a lot more going in Tunnel today Sent from my BlackBerry 9800 using Tapatalk
October 18, 201214 yr #4 Oh ok, iv had an f6 sedan do that and the bolts that connect the front shaft to the dampner were loose, also if you have drilled rotors they can make a noise very similar. Make sure the rear tonewheels on the end of the cvs are clear of debris etc
October 18, 201214 yr #6 Author Thank for info mate will check Cvs this week end do have cross drilled give it a hit tomorrow in tunnel and get on brake slightly hear if noise changes. Sent from my BlackBerry 9800 using Tapatalk
October 18, 201214 yr #8 Author So its the pleasure and pain Sent from my BlackBerry 9800 using Tapatalk
October 19, 201213 yr #9 Had a ticking tail-shaft on my BAII that happened after the tranny was replaced.. Very evident when under load. They replaced it as well. Luckily under warranty.
October 19, 201213 yr #10 Stealing this..Bionic-those white plastic spacers in a ba tails haft where it connects to the diff,, are they needed?
