  • Member For: 13y 8m 26d
Hey guys
sorry its probably so simple but has me stuffed. HTF do you remove the ECU? It has 3 of those weird screws that are flat on top, its like u have to grab them with pliars and turn them but they wont budge, its got me stumped. If it means making me look like an idiot feel free but plz help haha
cheers guys
https://www.fordxr6turbo.com/forum/topic/77366-ecu-removal/
  • Member For: 16y 10m 18d
You can use vise grips for a better grab at them or I have also used side cutters vertically.
If they are really really tight use a pin punch and small hammer.
Hit the pin punch on the outer edge of the screw head, leave the tip of the pin punch in the divet you just made.
Lay the pin punch over and tap with the hammer in an anti clockwise direction.
I replace these screws with stainless allen key bolts.
https://www.fordxr6turbo.com/forum/topic/77366-ecu-removal/#findComment-1149816
  • Member For: 16y 6m 30d
Use small hacksaw to make flat head screwdriver groves, I found a dremel with a cutting wheel works best to advoid sawing the ecu cover. Then untighten like any other screw. Hex key replacement is the go.
https://www.fordxr6turbo.com/forum/topic/77366-ecu-removal/#findComment-1149864
