  • Member For: 15y 9m 21d
Posted
So after months of replacing things to get my car running right again... still no luck.
ill start with the car - its a 03 ba xr6 turbo, no mods other than k&n(spending too much to get it running, would have loved to spend that money on mods)
Im experiencing spluttering and stalling, both idling and normal driving. the spluttering is worse once I hit boost - so im thinking fuel?
ive replaced turbo, injectors, plugs, leads, fuel filter, and still got the problem.
The last mechanic I took it to said because its not constant it could be electrical, made a bit of sense so ive ordered new coils (will be here tomorrow).
Also noticed that my ABS light is flickering as its shuddering.
Now he's had the car a bit more he's saying fuel pump.
I called a few mobs (hitech, coventrys, auto1 ect) and they all say that you cant just replace the 'pump' you have to buy the whole cradle.
Is this true?
Im sure I saw some pumps advertised as 'direct replacement' for xr6 turbo.
Im not looking to upgrade to something massive, but I would like to keep it as an intank pump and as close to standard as possible, unless its around the same price to put a slightly bigger one in?
I know the gss 340 is intank, but will it fit in standard cradle ect?
So, is there a direct replacement for a ba xr6 turbo fuel pump?
