  • Member For: 14y 4m 13d
I went and had a look at a fg xr6t, the guy had a little prang nothing to major, but the main issue is when driving it makes a massive continuous clunking noise. He said a mechanic told its the tail shaft.
Sometimes while driving it went but most of the time it was this real bad clunking noise wasnt coming from engine bay but rather well it seamed under the console, if anyone has any ideas thatd be great.
https://www.fordxr6turbo.com/forum/topic/73638-fg-xr6t-clunking/
  • Carnage on the Garage Floor
  • Member For: 15y 2m 7d
sounds like another diff bush failure me thinks - except wouldn't explain proximity to console.
Edited by bomber
  • Member For: 17y 2m 12d
Manual or auto. All manual fgs clunk. They have higher than normal shaft play. Under my Ute I can turn the tail shaft 20 odd mm while its in gear. So every time I go from no load to load it clunks. Ford rekon its normal.
  • Member For: 14y 4m 24d
I get this too, how annoying is it.
  • Member For: 16y 10m 14d
I have it when I am crawling up a hill.
I too would like to know what it is so I can perhaps squeeze it in for a warranty job before it expires. Obvously something with the drive shaft...but what?
At least I can replicate it....just find me a hill to slowly drive up, and clunk clunk clunk with every revoution of the shaft, so it would seem.
  • Member For: 15y 25d
You aren't confusing this with thrust bearing noise? which would be more of a grinding noise and is also common on fg manuals (mine has it).
Edited by RHR
No need to quote above post. USE FAST REPLY
