January 17, 201115 yr #1 I bought some brand new f6 rspec shocks off ebay and I am unsure if the require the longer or shorter springs (this is only for the fronts yes ? Rear is same as ba?)Pat has explained to me I need to measure from the bottom mounting hole of the shock up to the spring seat.When I do this I get a result of around 265mm ? Maybe im measuring from the wrong spot to the wrong spot ? I really dont wanna order the wrong springs and have to send them back lolThanks
January 18, 201115 yr #2 265mm sounds like you would need the longer springs but I wouldn't quote me on it.Personally I have an FG but recently I helped a member on here lower his BF MKII and he used the longer springs.Why dont you just call Wholesale Suspension and give them the measurements
January 19, 201115 yr #4 Anything built after 07/07 should have the short spring installed.Should have asked me mofo, as I have both at home. I could have measured for you. Edited January 19, 201115 yr by arm79
January 20, 201115 yr #5 Author dude I had those rspec shocks off kyle !!! I have no idea what they were out of
