November 27, 201015 yr #1 Hi all. This topic is probably similar to others posted, but I haven't found any quite like this one, so hopefully someone can help.I have a Blackberry Torch with OS 6.0. When I connect this to my FG XR6T, all seems to go well - they pair up, they connect quickly, etc, however whilst I can make calls, I cannot receive any.If someone calls me, my Blackberry rings, but this does not go through to the handsfree. Once this has happened, the system seems to be "stuck" - I cannot dial out with handsfree, and when I turn my bluetooth off on the phone, the car still registers as being connected (until it times out after a few minutes).This also happened with my Blackberry Bold 9000 when I installed OS 5.0 - OS 4.60 worked beautifully.I checked with my Ford dealer, and I am running the latest software for the car's bluetooth unit (altohugh they didn't tell me what version). This concerns me a bit as my car is March 09, and the latest Bluetooth BPM (according to Ford) is September 09. I'm not sure if they upgraded the unit duringthis year's service.I have messed around with various configuration settings on the phone, but nothing seems to work.I am not using a fancy ring tone, as I read this can cause problems. Someone also told me to turn off data streaming as this was a cure for some HTC units - I tried this but still no luck.Has anybody experienced a similar set of scenarios?Does anybody have any suggestions? Is there anything I can do to the car's unit (from the dash)?ThanksTMOC
November 29, 201015 yr #2 My 9700 Bold works perfectly. Except I don't get the ring tone through the stereo like I used to with my Nokia. Bit annoying. They all seem to work a little different. But send and answer calls - no problem. Edited November 29, 201015 yr by Pete A
