  • New Member
  • Member For: 15y 7d
one of my gaskets keeps leaking on one of the oil lines to the turbo I think. was wondering if anyone knows what this part number is from ford..... basically if looking from underneath its the gasket for the line that connects to the lhs of the block, very close to the alternator. any input appreciated
https://www.fordxr6turbo.com/forum/topic/71257-turbo-oil-line-gaskets/
  • 570Nm @1800rpm
  • Member For: 21y 7m 25d
Oil feed are cooper gaskets and oil drain are metal gaskets. I got the part numbers at home and can post later on tonight.
For info about the feed line and gaskets, have a look at the Oil Feed sticky thread in the Turbo section.
Edited by XtRmn8
  • New Member
im pretty sure its the oil drain... that part number would be great thanks alot mate!
  • 570Nm @1800rpm
Water line copper washers for banjo fittings: "W 700762 S300"
Oil feed copper washers for banjo fittings: "E 832149 S300"
Oil drain gaskets: "BA 9Y478 A" and "BA 9Y478 B", top and bottom are different and I do not know which is which.
