September 8, 200917 yr #1 Trying to see what combo's are out there. This is meant for all the people who have a new ECU and use pump fuel only.* What car model* What ECU* How much boost* How much timing* What dyno resultIm lookin at 17-18psi with 12-13 degrees timing for 310-330rwkw. Will know tomorrow
September 8, 200917 yr #3 18psi for only 330wkws?Is this for XR6T cars or XR6T motors in other cars... majority of us use the stock ecu, no need to change
September 8, 200917 yr #4 pretty sure he's talking about an xr6t Rap1d as he just got more mods for his
September 8, 200917 yr #5 running that much boost u should get min 340rwk or somethings wrong.and that's with standard ecu
September 8, 200917 yr #7 18 PSI is on the high side for a stock engine period, let alone with 13 degree's as well. That boost (assuming mostly stock intake/exhaust) should see that power or more on factory timing. If you have a ZF or manual box (thus not losing much kw reading like a BTR with/without stall would) someone has serious issues mate.
September 8, 200917 yr #8 Author sorry as im new to BAs and how they work, I was under the impression you just replace the ecu's with a management system like a wolf 3d / motech system. Im aware 80% of us use capa flash? This like a piggy pack unit that reprograms the stock ecu right?I have no idea on the boost/timing these use apart from all the searching ive done.The thread is for people who run more then 16psi I should say. Usually to run that im gathering you would already need exhaust, valve springs and new cooler so those in mind, then the above is what I am trying to refer to.And no BFHOON, the car came wiht a full APS exhaust and an EXED Chip (which im still trying to work out what that is / does) Edited September 8, 200917 yr by icer
September 8, 200917 yr #9 Ok, so get my car back tomorrow....excited what final figures it will get. As it is an Auto and has a histall im aware the figures will be bout 15~rwkw lower then a normal manual but no worries, on the track will show a better RT :DAnyways, as of tomorrow what will be done:60lb DEKA injectorsAVO Stage 2 Intercooler kitWalbro Fuel PumpCapa Flash x3Some spark plugs with some sort of gapping AVO put in12psi actuatorlarger flappernizmo valvespringsK&N Flatpan filter5" Cool Air induction pipe from passanger driverlight/fog light to airboxFull APS Stainless Steel ZorstRebuilt strengthened 4sp Auto + shiftkit + 2800rpm histall + transcoolerAny ideas what power I should be expecting?sorry mate I was going off the above quote.they will probly remove the exede when using the xcal 3
