  • Member For: 15y 9m 13d
Update, installed the trans cooler and temp gauge and a pressure gauge, ended up adapting some high pressure air compressor adapters to run the temp sender and pressure sender. works well just need a higher pressure gauge as the trans pressure is very high.
All up the adapter block was about $30 and works well.
Thanks for advice given
