August 8, 200917 yr #1 When I turn it seems like something is grinding, have pin pointed it to either the front or rear wheels/suspension (depends on how sharp the turn is)There are no signs of rubbing or anything like that. I just have no friggin clue whats going on :SI never noticed it before I put on pacemakes. Sometimes it seems its comming from the engine bay as well.Any help is appreciated :o btw car is fg xr6/na
August 8, 200917 yr #2 hey mate I had a very very similar problem with my car last year, grinding sound when turning (and depending on how sharp the turn was) it ended up getting worse to the point where it started grinding constantly. Ended up being the ball joint (R/H/F ball joint or something cant remember exactly what it was called) had come loose. Dont know bout the FG models but it'd be worthwhile having checked, cost me $350-400ish to get fixed.hope it helps
August 12, 200917 yr #4 hey man I just had that problem recently it could be 2 things you could of snapped an axle or broke a CV joint I picked up the part for 200 bux but I did the work my self as well its a bit of a ball breaker job and you might need 2 ppl to help you after your done go get a wheel alignment and everything should be fine good luck mate
