Crow Cams Valve Springs Specs
Featured Replies
#1
Does anyone know the specifications of other valve springs ie: atomic, performance, nizpro etc
Also is anyone running Crow Cams Valve springs part number 1808-24 or VTKBA6T-24 with retainers
The specs for 1808-24 are:
INST.Height. 1.44''
INST.Pressure. 90
Pressure @ .5 Lift. 195
Max Lift. 0.55''
Solid Height. 0.90''
Are these any good for 300rwkw
I got my set for $400 with retainers.
Or you can get a race set. Specs:
INST.Height. 1.44''
INST.Pressure. 115
Pressure @.5 Lift. 225
Max Lift. 0.55''
Edited by F6RD
#2
You got the 1808-24 with retainers? You know you could use factory retainers with the 1808. The ovate 1809 has a little too much seat pressure with standard retainers so crow have a .030" offset retainer to reduce pressure.
#3
  • Author
Yeah I got the 1808-24 with reatiners.
Fair enough, so I didnt need the retainers.
Bloody salesman could have told me I didnt need them SOB.
but I guess the question im asking is, are the specs good and are they a good Valve spring?
#4
I don't know from personal experience but I don't see them being too different to the other springs on offer.
#5
I have crow valve springs and pushing 375rwkw but I paid $900 with retainers
#7
Mate I have standard valve springs on a ba and 300RWKWs so if you cant find 300 then whats the point
#8
BA valve springs are troublesome. Even with a factory tune, a BA will pull harder from around 4000rpm with valve springs.
#9
:nerd:
mine started to shiit emselfs after a 12psi tune.
got crows put in n now running 14psi daily with no issue.
#10
  • Author
You were pretty lucky then Mate, not having to install new valve springs, cause its exy.
Edited by F6RD
Recently Browsing 0
